Old 09-26-2007, 04:04 AM
beaser beaser is offline
1998 dodge caravan
just got the van and 4 lights on the pannel are flashing, rear wiper, rear wiper/washer, recirculator and ac i am sure that it is a code, can i turn it off????
Old 09-26-2007, 08:27 AM
earlyrizr earlyrizr is offline
Re: 1998 dodge caravan
the panel can be recalibrated as long as the AC works correctly
1] start engine
2] slide AC controls to the left
3] set vent to vent-face
4] fan control to full -high
5] Press AC (snowflake) Button and Rear Washer Button At The Same Time (Both Together)
6] Hold until All Lights Illuminate Together
7] Release AC & Rear Washer Buttons
8] Unit will Cycle for a few minutes
9] When done - lights will stop flashing.
If it doesn't work the first time - try it again. you may also need to have the parking brake applied for this to work
Old 09-28-2007, 05:19 PM
thanks for the help. now for another question. i now have 2 blinking lights, the ac and the recirc. i am sure it is because the clutch is not running. i checked the pressure on the low side ( approx 25 lbs at 65 degrees ) i removed the plug for the clutch and i get no power. i can activate the clutch with jumpers, any more suggestions????
