Any help would be appreciated, thanks.
I have a 96 eldorado, the Service engine soon light is on along with the Traction control light and the Brake light. I am also getting the the "Service emissions system" message, along with "Service ignition system" message. Also the "theft system problem" message. Yeah thats right the thing is falling apart. The car will sometime idol at 1200 to 2000rpms, if I turn off the car and restart it a few times it will return to normal idol. Its idols loud too (all the time). Any Ideas? Also whats the difference between "History and Current", is it as simple at it sounds?? Current means its a current problem??Heres the codes... PC0122 History PC1122 History PC1350 History PC1375 History PC1406 History PC1579 History IP1552 History IP1910 History IP2711 Current No ACM No SDM TC0033 Current TC0083 Current No RSS No PZM No IRC No RFA No CCP PCM? Thanks again in advance. |
Re: H-E-L-P! 1996 Eldorado Code
Often a lot of unrelated codes are due to the computer receiving low voltage and thus producing bogus codes. Check and clean the battery connections and grounds. Inspect the cables themselves for swelled areas which would indicate internal corrosion. Check the battery voltage across the terminals as well as charging voltage.
