Old 09-25-2007, 07:07 PM
zebra111 zebra111 is offline
1992 PA Will not start when hot DTC 17
I am new, 1992 PA 3800, runs great when cold, after turning off will not re-start. If left alone for an hour or so starts and runs fine. Pulled code 17 spark reference circuit?????
Old 09-25-2007, 08:58 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Red face Re: 1992 PA Will not start when hot DTC 17
Welcome to AF! I assume with a code 17, that you do not have spark when it don't start. That would indicate the crank position sensor (CKPS) is not doing its job. You could also have a “failure to communicate” from the CKPS through the ignition control module (ICM). You need to check for spark when it will not start and if you have a tach or scanner, check for RPM. If no RPM is indicated, replace the CKPS first!
Old 10-01-2007, 08:41 PM
Replaced crank position sensor over the weekend, codes are gone, and runs great once again!!
Thanks AF
