Old 09-25-2007, 04:50 PM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
emissions problem/question
ok i have a a 98 3000gt base model sohc..i put long headers on it a while back ( eliminating my egr ), as you know there is a spot on the intake manifold for the egr piping that goes the the rear stock exhaust manifold then another spot on the manifold where what i call the egr valve, not sure if thats what it is..but i left the egr valve on just blocked off the piping thing, cuz the valve had a hose line to it so i left it alone, my CEL has been on the hole time since the headers, i tried today taking the plate off, leaving an open hole in the intake manifold to get some clean air in so the egr can actually be functional, and reset my battery to clear the CEL light for know to see if it turns back on, hopefully not..i dont get it..why does removing the egr pipe trigger CEL, the motor is running cleaner now..it should be happy! why CEL!?!?!..any ideas on how to keep the light off, assuming its coming back on, which it probly will...
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm summit throttle body
85mm bbk ssi intake
fast fuel rails
30lb ford racing injectors
spohn strut bar
msd ignition coils
msd 8.5mm spark plug wires
edelbrock shorty headers
upgrade cam/ port and polished heads
SMG dyno tuned ( 375 rear wheel hp )
magnaflow cat back
slp y pipe
umi bolt on subframe connectors
umi rear control arms
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 09-25-2007, 04:51 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: emissions problem/question
buy a JDM ECU
Jason
EDIT- never mind.. you are OBD2 so that wont work..
Old 09-25-2007, 08:47 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
You dont want to leave the hole open. That will be a HUGE vac leak and the car wont stay running.
The EGR is supposed to somehow make the engine burn cleaner. What the fuck ever. There are ways OBD2 guys are able to remove the EGR and keep the CEL from lighting. you just have to look around to find the answers
Old 09-26-2007, 04:59 PM
see i thought the same thing about a huge leak..but that hole out the manifold SUCKS air, not blow..so when ever the egr valve opens it just sucks air..which for the most part is clean, i was just gonna buy a mini air filter and get it to stay in there to protect the hole..but as long as it keeps my CEL off, im happy..
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm bbk ssi intake
fast fuel rails
spohn strut bar
msd ignition coils
magnaflow cat back
slp y pipe
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 09-26-2007, 05:17 PM
Stealthee's Avatar
It wont keep the CEL off. You will suffer a huge loss if the car even runs. And also think about it, I said a VAC leak. VAC as in vacuum, of course it sucks air. Do not do it.
Old 09-28-2007, 03:30 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
sigh...
leaving that open will allow all kinds of unmetered air into your engine...thats a BAD thing. Block it off, and search for a way to turn off the CEL. Pretty sure there's a 10 cent resistor fix for it.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 09-28-2007, 11:28 AM
no you guys are wrong..my car is running great..the egr valve NEEDS to breathe, meaning you cant block it off..i just took my previous block off plate drilled a hole and welded a tube on it with a filter on the end so it dont suck any items or dirt down..my car is ideling and driving as good as ever now..and check engine light has been off for over a week since ive done it..plus resistors only work on 1st gen gts..not 2nd..
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm bbk ssi intake
fast fuel rails
spohn strut bar
msd ignition coils
magnaflow cat back
slp y pipe
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 09-28-2007, 11:39 AM
Maybe I understood wrong what you did...so you disconnected where the EGR connects to the header and put a filter there? Like that it would operate normal except it would just be putting in normal air instead of exhaust gas when the EGR opens...which still means you're running a bit lean whenever the EGR opens up...but since it only opens under light/moderate load it should be fine. (lean because normally the gas the EGR puts in just takes up space in the combustion chamber and hinders combustion rather than helps it, plus lowers comb. chamb. temps)
Want to take a picture of it? I'm interested to see it.
Old 09-28-2007, 06:12 PM
yes that is exactly what i did..ide be happy to take pictures..how do you post them???
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm bbk ssi intake
fast fuel rails
spohn strut bar
msd ignition coils
magnaflow cat back
slp y pipe
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 09-29-2007, 12:34 AM
create a free account on www.photobucket.com and upload the pics to there, then link them here.
