Old 09-25-2007, 03:34 PM
chosen1 chosen1 is offline
amp installation question
i am planning to install two 10s in my 00 silverado. my question is, where can i run the power cable from the battery to the amp? do i have to drill a hole through the firewall?
any suggestions would be appreciated.
Old 09-25-2007, 03:52 PM
knogoodidleft knogoodidleft is offline
Re: amp installation question
what kind of cab do you have?
Old 09-25-2007, 04:41 PM
rjeffery rjeffery is offline
I ran mine through an existing hole above the brake pedal. You can see it better if you look at the firewall on the engine side. Then I ran the wire under the plastic trim piece along the edge of the floor.
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 09-26-2007, 07:40 PM
its an extended cab
Old 09-26-2007, 08:53 PM
Not sure about the extended but on the crew cab there is a plastic like metal punch out plug, I just took the plastic door/carpet mold peice off and pulled back the carpet a foot or so and the plug is right there, if its there you should be able to see it by looking under the cab. Just pull out the plug, take a drill and make the same size hole as your amp wire, put the plug back and seal it with some silicone, I ran my wire from the battery to the chassis, just zip tid'd all the way, make sure its far away from the exhuast.
Old 09-26-2007, 10:32 PM
Bill-SILV Bill-SILV is offline
I had a 99 ext cab and there was a plastic knock out you could take out like the post before me said. I just left it out but it would be alot nicer to do like he said and drill a hole and silicone it. I wanna say it was to the left of the brake pedal on the firewall.
