Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 09-25-2007, 02:08 PM
cantfixit cantfixit is offline
92 engine
hello, I have a 92 towncar that my wife severely overheated, warping heads and who knows what else, I've been looking for a replacement engine and was wondering if a 93 or 94 4.6 engine would work, some have told me it would, others say it won't, any technical advice would be appreciated.
Old 09-26-2007, 04:57 PM
Towncar's Avatar
Towncar Towncar is offline
Re: 92 engine
If you need a 93/94 FSM goto my website and get one for free.
-Steven
1996 Town Car, Cartier
Old 09-29-2007, 03:51 PM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Re: 92 engine
In 93 they started using a three bolt starter. That could give you problems there. I would sugest using a 91 or 92 engine and not a 93 and up. But you might want to check if you have the 3 bolt starter, if it was a later 92 model. I have three good engines that would work in your car. They all run good, no noises or smoke. Mileage rangeing from 80 to 130 k starting at $400.00 Complete minus the accessories. From 91 models, I also have one from a 93 model. I also have heads, intakes, etc from these cars. Let me know if you are interested. [email protected]
thanks
Mike
Old 10-03-2007, 12:43 AM
reekor reekor is offline
Re: 92 engine
The 3 bolt starters were used after 11/91 in the town car and 2/19/92 in the crown vic and grand marquis. The 2 bolt starter blocks share the same transmission bolt pattern as the 302 block, as the 3 bolt starter blocks do not.
thanks
Mike
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
