Old 09-25-2007, 11:03 AM
dtoolman dtoolman is offline
Talking Low fuel and check gauges light stuck on
I have a 1992 Pontiac Grand Prix 3.1 160,000miles. I have a low fuel light comming on, but plenty of fuel. It also causes the check gauges light to come on and stay on as well. I have been told by Pontiac that the problem is the panel/gauge cluster, and to replace it. Last time I checked it the cost was around $500, and can't find one in a salvage yard. All I want to do is "disable" it. I know that on this car when the low coolant light comes on all you have to do to get it to turn off is to unplug the sensor on the radiator. Is there a sensor I can disconnect, or a wire I can cut, to get the "Low Fuel" light to go off? This light is driving me mad,and I don't need it. Thanks
Old 09-25-2007, 01:13 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Low fuel and check gauges light stuck on
About all you can do is remove the bulb for it from the cluster.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-25-2007, 08:41 PM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
I second what Rich advised. I used to own a 91 GP 3.1 SE and I was able to get behind the cluster and terminate the check gauge light that was always on because of a bad cluster. If I remember correctly, I used some needle nose pliars and crushed it and it felt good!
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 09-27-2007, 08:27 PM
Smile Re: Low fuel and check gauges light stuck on
Thanks guys. I had thought of that but then I'd have to remove the cluster. Oh well if that's the only way I'll do it. I was afraid the solution was going to be removing the fuel tank and snipping a wire. I like your solution better (and much easier too) Thanks, again.
