Old 09-24-2007, 11:51 PM
JeenyusVR4 JeenyusVR4 is offline
Short throw shifter
ok so today i was driving my car around and i have had an Ultimate Performance adjustable short throw shifter on it for a while now and it just broke on me. Kinda pissed off about. I also had some troubles with it in the beginning as well. So i will definately not be buy from them any time soon. I was just wondering if there are any other types out there.
Old 09-24-2007, 11:58 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: Short throw shifter
You can make your own.. do a little searching for it.. in fact.. I think its in the FAQ
Jason
Old 09-25-2007, 10:18 AM
X2Xtreme360 X2Xtreme360 is offline
I didn't like my UP shifter either. My problem was it grinded against the side when I would shift. All I did was took the stock shifter base and used that with the short shiter rod. You have do minor customizing. All you have to do is turn the rod backwards so the part where you put the shifter linkage on is facing the other direction and punch out the little white plastic peice going through the hole in the base. It feels stock and gives you a shorter throw. Very satisfied.
Current mods:
Cold air intake
Magnecor 8.5mm competition wires
NGK copper spark plugs
Polished Plenum
KillerGlass radiator hose
