Old 09-24-2007, 09:22 PM
91mitsubishi3000gt 91mitsubishi3000gt is offline
Unhappy not sure what is wrong with my car
I have a 91 mitsu. 3000gt SL. she burn oil and lately she will hesitaite at around 2000 - 3000 rpm. b4 2000 and after 3000rpm shes fine. i dont know what to do
Old 09-24-2007, 10:32 PM
2old 2old is offline
Re: not sure what is wrong with my car
The 2 problems might be related...
Have you checked if the oil is leaking through the valve seals? It could have fouled the spark plugs which is causing the hesitation...
If not, the hesitation might be worn out plug wires or cracked coils.
Old 09-24-2007, 11:36 PM
new2mitsu new2mitsu is offline
+1 on plugs n wires
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 09-24-2007, 11:57 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
I don't know if the non turbo ecu has the same problem (I think it does) but you might look into leakin caps on your ecu.. thats what is sounds like to me.. however you might as well change the plugs and wires anyways just to rule them out..
Jason
p.s. I can hook you up on factory parts as well as give you some killer deals on after market parts like NGK plugs and wires in this case..pm me if you interested
Old 09-25-2007, 10:21 AM
every time I change my spark plugs there is oil on them. the plugs are only a month old, same with the wires. the coils are only about 3 or 4 months old.
just last night my battery died. i diconnected the battery then reconnected it and gave it a jump after words the hesitation doesnt seem to be as bad. im new to a v6 eng. but i feel that I should have more power than it is giving. it seems that i have the same power or less with a 4 banger eng.
Old 09-25-2007, 10:37 AM
lately my mpg isnt as good as it used to be (ever since the hesitation).
also what would happen if i took the air resinator off to put an performance air intake on?
Old 09-25-2007, 02:58 PM
mistermoonpie mistermoonpie is offline
I did the same thing taking off the air resinator on my 97 sl and I dont even have a performance intake on it yet (damn ebay. The only thing that will happen is you will notice a slight increase in sound quality and volume when you get into higher RPMs. At least thats what happened for me.
Old 09-25-2007, 03:44 PM
Ugh... How much time/money do you want to spend on fixing it?
If it were me... I would personally look into replacing the valve seals in the intake to stop the oil leaking onto the plugs... I am not sure if that is the exact problem but unless you start fixing the obvious stuff you won't be tell if it's something less obvious (IE: you will just end up throwing parts at it).
Old 09-25-2007, 03:56 PM
dhrubio's Avatar
dhrubio dhrubio is offline
Send a message via AIM to dhrubio
A clogged fuel filter causes hesitation, so put in a new one.
Pics
Old 09-25-2007, 04:05 PM
And have fun w/ That
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 09-25-2007, 04:06 PM
jason_bet's Avatar
and engine.. thats what I think.. get a new engin and it will prabably fix it.. if that doesnt.. I would get a new tranny..
Jason
