Front Suspension Noise
Been getting from suspension noise and see attached
Do you have a loose Audi control arm, ball joint, or suspension rattle? Does your Audi front suspension clunk every time you hit a pothole? You may need to replace your Audi control arms and control arm bushings. Replacing Audi control arms one by one can cost a lot of money. You'll save big on installation costs when replacing all of your Audi control arms at once. If some of the control arms are on their way out, the others aren't far behind. You're better off getting the job done right the first time.
Save hundreds of dollars by replacing all of your Audi control arms, tie rod ends, sway bar links, and hardware with our convenient updated kit! In the event of an Audi control arm failure, look to the nation's leading Audi control arm specialist for the solution!
What does everyone see and recommend? This is BLAUparts answer. what does everyone think? I have a 99 A4 with sport package and am experiencing this clunking, ect.
