Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 09-24-2007, 07:02 PM
clee1976 clee1976 is offline
97 Avalon Starter Runs Continously
Starter runs conrinouusly when starter is hooked up. I have already replaced the starter relay and that was not the problem. Any advice?
Old 09-25-2007, 05:05 AM
tfeld tfeld is offline
Re: 97 Avalon Starter Runs Continously
The relay is not your problem; it's the starter contacts.
The starter has a magnetic switch assembly attached to it (it's the part where the positive cable is attached). Inside is a set of copper contacts and a plunger. When the contacts get worn from use, they can/do develop a ridge which can trap the plunger, keeping it engaged. Contacts and plunger are cheap and easily replaced.
DON'T hook it up until you get this fixed. If you do, you'll end up frying your starter, alternator, and possibly even starting a fire.
