Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-24-2007, 02:34 PM
devildogg4201981 devildogg4201981 is offline
Lightbulb will it fit???
I want to know if i can put a 2.0 head on a 1.8 block and make it work
Old 09-24-2007, 04:02 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: will it fit???
My guess would be no. The 2.0 is a dual over head cam while the 1.8 is single over head cam. I don't see the block and head lining up at all.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 09-24-2007, 04:14 PM
KoDKingVegeta KoDKingVegeta is offline
Re: will it fit???
The 1.8 block is the SAME as the 2.0 block. The 1.8 is SOHC well the 2.0 is DOHC, the 1.8 is a 4G37 the 2.0 is 4G63. Look it up, its the same block, turst me I no everyone told me I couldn't install a 2.0 into a 1.8 frame because the motor mounts were not the same (turns out its the SAME block as the 1.8). Just look it up, there will be ALOT of work to make it work, but the 2.0 will install right onto the 4G37.
1989 Honda Civic DX Hatchback
*STOCK
Twisted Motor Sports
The Cell Games
^--Help Revive an old forum, Come Join
-=flash to the future: (three months) "As stock prices continue to climb for superglue... ppl are frantic.... *static* KoDKingVegeta buys the whole market out *Static* fix *static* dashboard from *static* UK... *end of flash to the future*=-
Old 09-24-2007, 04:37 PM
Re: will it fit???
Well the 1.8 is 1775cc and the 2.0 is 1997cc. I didn't take too much time to look it up, but I read one article that said they were the same block just with a different bore. If you've already done it, then obviously its possible. I stand corrected.
94 Talon 1.8L-SOLD
Old 09-24-2007, 04:44 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: will it fit???
I was not aware of this either. This is good info to know.
Did you do the install and if so, what extra work did you have to do? Since you seem to know the most about the 1.8 to 2.0 swap can you enlighten the rest of us so we don't spread bad info anymore?
1991 GSX 2.3 Stroker
