Go Back   Automotive Forums Car Chat > Ford > Econoline
Old 09-24-2007, 01:57 PM
Jonuss2002 Jonuss2002 is offline
89 Ford E150 Econoline Van Won't Start!!!
Ok.
Having a problem with a Non-starter!!!!
Drove it to my shop and it stalled out. Was able to restart and it started fine. Moved it to the parking space (aprox. 50' away). Died again in the parking space and has not started since.
Replaced;
Fuel pump
Fuel regulator
and Under hood Relay (Green).
We can pour gas into the hose that leeds to the throttle body and it will start (until the gas burns out) then it just turns and turns but does not start.
Please let me know what else I can try.
Could it be an air bubble in the line somewhere?
Old 09-24-2007, 10:58 PM
Davescort97 Davescort97 is offline
Escort guy
Re: 89 Ford E150 Econoline Van Won't Start!!!
It could be that the fuel filter is obstructed. Did you replace it? Can you put a fuel pressure gauge on the fuel line to check it for pressure. It should read around 45 lbs. It's defnitely a fuel starvation problem. Wouldn't be a bubble in the line as it would dissipate as soon as the pressure went through.
Old 10-30-2007, 09:41 AM
rockwood84 rockwood84 is offline
sounds like fuel relay or fuelpump not working or fuelfilter stopped up
Old 02-16-2019, 02:46 AM
ednja ednja is offline
It sure would be great to see solutions for some of these problems!!!
Old 12-23-2021, 03:33 AM
I forgot all about this thread. I worked on the same van a few years ago that was also a no starter. That's why I commented on it. I did get that van going. It was one of the 2 large relays by the battery. I think there's 2 of them or maybe it's 3. Not sure. I'm guessing it was the fuel relay. It's been too long now so don't remember the details. With the scamdemic and Bible prophecies happening before our eyes, I haven't been doing much car work the last couple years.
