Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 09-24-2007, 02:21 PM
Stevea100l Stevea100l is offline
94 Cutlass supreme Cooling fan
I just boght a 94 cutlass and the driverside cooling fan stays on. Even after i turn the key off it still runs until you pull the relay. I have replaced the relay and it still does this. Whay should be the next thing i check and were is it located on the motor
Old 09-24-2007, 06:46 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 94 Cutlass supreme Cooling fan
Welcome to AF.
Are you certain you replaced the right one ?
If you have two fans then thier are two relays.
Other then that you'd have to have a short in thier somewhere, fuse box maybe
1999 Grand Am SS 3.4 OHV
Old 09-24-2007, 09:36 PM
Well i moved the relays around to double check but someone thought the pcm might have a short to stick it on
