Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 09-24-2007, 08:37 AM
JustCris JustCris is offline
Code P0430, cat' effectiveness
below threshold, bank 2.....
This is the code I'm getting on my '96 Tahoe.
Looks like a cat replacement is in my future.
What's the chance of doing this myself? Got a feeling
it's going to be a rusty mess down under the truck......
Bank 2???? What does that mean??
Cris
Old 09-25-2007, 09:51 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Code P0430, cat' effectiveness
Cris
Bank 2 is the right side cat.
But a code does not say replace the cat.
Many engine running and o2 sensor problems can cause a cat code.
First thing check engine running and tune up end.
A little info on cat codes.
http://www.troublecodes.net/articles/catfailure/
DTC P0420, P0421, and P0430 & P0431: Check Possible Cause Of Misfire DTC P0420 and P0421 indicate bank one catalyst system efficiency is minimum requirement. DTC P0430 and P0430 indicate bank 2-catalyst system efficiency is minimum requirement. Possible causes are as follows: Use of leaded fuel. Oil contamination. Cylinder misfire. Fuel pressure too high. HO2S sensor improperly connected. Damaged exhaust system component. Faulty ECT sensor. Faulty HO2S. Ensure ignition timing is correct. Retrieve all Continuous Memory DTCs. If misfire code is not present, go to next step. If misfire code is present, isolate cylinder and repair as necessary. Check HO2S Monitor DTCs If DTCs P0136, P0138, P0140, P0141, P0156, P0158, P0160, or P0161 were present in step 1), service as necessary before continuing. If none of these codes are present in step 1), go to next step. Check ECT Sensor DTCs If DTCs P0117, P0118, P0125 or P1117 were present in step 1), service as necessary before continuing. If none of these codes are present in step 1), go to next step. If any codes except P0420, P0421, P0430 and/or P0430 were present in step 1), service as necessary before continuing. If no codes except P0420 and/or P0430 were present in step 1), go to next step. Check Rear HO2S Wiring Harness Turn ignition off. Ensure HO2S wiring harness is correctly routed and connectors are tight. Repair or replace as necessary. If wiring harness and connectors are okay, go to next step. Check Fuel Pressure Turn ignition off. Release fuel pressure. Install fuel pressure gauge. Start engine and allow to idle. Note fuel pressure gauge reading. Increase engine speed to 2500 RPM and maintain for one minute. For fuel pressure specifications, see FUEL PRESSURE SPECIFICATIONS article. If fuel pressure is as specified, go to next step. If fuel pressure is not as specified, go to CIRCUIT TEST HC. Check For Exhaust System Leaks If exhaust system leaks, it may cause catalyst monitor efficiency test to fail. Inspect exhaust system for cracks, loose connections or punctures. Repair or replace as necessary. If exhaust system is okay, go to next step. Check For Exhaust System Restrictions Inspect exhaust system for collapsed areas, dents or excessive bending. Repair or replace as necessary. If exhaust system is okay, go to next step. Check Manifold Vacuum Install tachometer. Connect vacuum gauge to intake manifold vacuum source. Start engine and raise engine speed to 2000 RPM. Manifold vacuum should rise to more than 16 in. Hg. If manifold vacuum is okay, go to next step. If manifold vacuum is low, go to step 11). Leave tachometer and vacuum gauge connected. Start engine and raise engine speed to 2000 RPM. On a non- restricted system, manifold vacuum should quickly rise to normal range as increased RPM is maintained. On a restricted system, manifold vacuum will slowly rise to normal range as increased RPM is maintained. If manifold vacuum is okay, no indication of exhaust leak or restriction has been detected and testing is complete. If manifold vacuum is low or slow to respond, go to next step. Leave tachometer and vacuum gauge connected. Remove exhaust pipe from exhaust manifold. Start engine and raise engine speed to 2000 RPM. If manifold vacuum is now okay, fault is downstream from exhaust manifold. Reconnect exhaust pipe to exhaust manifold and go to next step. If manifold vacuum is still low or slow to respond, fault is in exhaust manifold or intake manifold gasket. Repair or replace as necessary and repeat QUICK TEST. Leave tachometer and vacuum gauge connected. Disconnect muffler/tailpipe assembly from rear of catalytic converter. Start engine and raise engine speed to 2000 RPM. If manifold vacuum is now okay, fault is in muffler/tailpipe assembly. Repair or replace as necessary and test-drive vehicle to verify elimination of symptom. If manifold vacuum is still not okay, fault is in catalytic converter. Repair or replace as necessary. Check tailpipe/muffler assembly for debris from catalytic converter. Test drive vehicle to verify elimination of symptom.
MT
MT
Old 09-26-2007, 09:51 AM
Crap! But thanks for the reply, I'm sure it'll help. Truck isn't running.
Ran fine one night next am, no start. Only code in the system was the P0430. I have noticed that rotten egg smell for "awhile" now. Would this code actually keep the truck from starting or would a bad O2 sensor keep it from starting? I unpluged the battery for an hour hooked her back together & still wouldn't start.
My dirt driveway is a muddy mess, so don't want to lay around under the truck for the next few days. O2 sensors are definately cheaper than Cats, so I'll try that first....
Thanks for the input & the detailed instructions but I have none of most of the tools listed.
Cris
