Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 09-24-2007, 07:59 AM
Cheek341 Cheek341 is offline
Send a message via AIM to Cheek341
Unhappy engine swap from a 93 3.4 dohc to a 96 3100 sfi engine
Hi I am having probloms getting my 93 cutlass supreme to start.Over the summer I did an engine swap.I swapped out the siezed 3.4 dohc with a 3100 sfi engine.I transfered the pcm wire harness fuel lines. the engine came from a 96 cutlass supreme that was involved in a front collision. The engine will crank but it isnt recieving fuel.I no for a fact that the fuel pump turns on for 3 seconds then shuts off.The pcm gets power becuse it will try to start on starting fluid. would I have to replace the dash harness from the other car to make it run.
Old 09-24-2007, 05:42 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: engine swap from a 93 3.4 dohc to a 96 3100 sfi engine
Welcome to AF.
Yes I bet you have forgot a few things .
Not only the wire harness the ECU/PCM, EBCM, Pretty much the whole harness from the 96 3.1 and all the components that connect to the engine management systems.
Then you will most likly need a GM Tech II scan tool to get it set up and running.
So doubt it is getting proper spark or fuel.
These are not your mom and dads hot rods!
Good Luck !
1999 Grand Am SS 3.4 OHV
Old 09-26-2007, 05:51 AM
So basicly i have to rewire it and hook up all the moduals. I have the pcm for that engine hooked up. The power door locks dont work either.they worked when the other engine was in it. becuase i have everything from the 96 cutlass.My Uncle is a mechcanic and he said to get a key made for the theft deterent modual.The dealer said i had to either flash program it or it would haver to be towed to the dealer to reprogram it.
