Old 09-23-2007, 11:48 PM
Jaredmxg Jaredmxg is offline
Fuel Technical ? 4.3L
Well I will start out by telling you the symptoms. this truck is not daily driven and now that i have went back to start it up it is having fuel issues.
When i turn the key to ACC. once in a while the pump will prim. After that there is no chance it will prime
I can manually put power to the pump it is still good. I have checked all grounds relay battery pump, not ecm yet but i can bet it is a great ground.
On the firewall there are 4 relays mounted, the hanes manual says that 3 of them are for the ac which is incorrect cause i went threw them and put individual power to certian wires for running lights and other stuff to come on. so i think one of them is ac one is fuel pump one is oil something. and other running lights.
I am not 100% positive which one is the fuel pump relay but there is only one 5 wire relay and the manual says it has 5 wires none of which is color coded according to the book.
when the ignition is on the relay is getting no acc power. Is it suppose to be a 2 second momentary or ?
this is where im stuped.
i have read alot of forums on this and cannon figure what it is. I have been told it could be a bad computer or ignition module.
How could I test the 2?
Old 09-24-2007, 08:20 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Fuel Technical ? 4.3L
Welcome to AF
What year?
When it acts up do you have spark to more than one spark plug.
Does the fuel pump run when cranking the engine?
MT
