Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-23-2007, 11:12 PM
lostmypicks lostmypicks is offline
when will it stop
hi, some of you might remeber me, I blew my turbo then put on the 16g.
everything is running good with the turbo. but I am installing a rear differential
on talon then my clutch is starting to slip so I will need to do that and my CEL light is on and the coed reads that it is ignition system or misfire.
I want to know if anyone has had that coed before and what they did to solve the problem? but I know this is what owning a car is all about. oh by the way the reason that I think it is the rear diff is because I hear a clicking sound and a loud hum coming from the back of the car. it is louder around 60 mph.
any suggestions are welcome.
thanks
Old 09-23-2007, 11:15 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Re: when will it stop
wheel bearing? not sure... code number?
Old 09-23-2007, 11:35 PM
humm it could be a wheel bearing, but wouldn't that just be a hum and no clicking? off hand I cant remember the coed number I will check and get back to you on that. if it is the wheel bearing is that a hard fix?
Old 09-23-2007, 11:47 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
I really don't know anything about the rear ends in these AWD cars, because I've never fooled with them. But my home boy's Z-71 truck....the rear end was roaring bad...when he would pass my house cruising I could hear it roaring. Turned out to be the pinion bearing.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 09-23-2007, 11:49 PM
EDMUND65's Avatar
clicking usually is half shaft?
Old 09-24-2007, 12:11 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Dude! I just got a great idea! Why dont we make some subforums for different car related questions to better organize our forum! Oh wait...
Please use the subforums!
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-24-2007, 12:12 AM
Whats a half shaft?....You mean axle?
Caleb
vanilla gorilla
Old 09-24-2007, 11:26 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
I would say bearing before I said differential. Have you had anyone sit in the back seat and see if they can hear wether the sound is from the left or right side, or if it's coming from the middle?
1991 GSX 2.3 Stroker
Old 09-24-2007, 12:22 PM
sorry next time I will post in the sub forum.
I will have to have someone sit in the back today at work and see if they can tell witch side it is coming from. half-shaft?
one reason why I think it would be the rear diff is because it leaks oil, so I thought that mabe it has been running a little dry. i put more oil in it and it took a lot. I will have to start looking into the wheel bearing. thanks guys
and sorry again.
