Old 09-23-2007, 09:45 PM
swedishstar33 swedishstar33 is offline
Thumbs up 99 Ford Windstar LX
I just bought a 1999 Ford Windstar and was wondering where is the plug that you plug in a cd changer? My van didn't come with a cd changer and I want to put one in and was wondering where the heck to plug it in?? Thanks for any information you can give me.
Old 09-24-2007, 06:24 AM
busboy4 busboy4 is offline
Re: 99 Ford Windstar LX
Hi
Do you have a Ford OEM changer? I cannot say for sure whether it was an option in '99, but that would be the only way one would simply "plug in". If you are wanting to add an aftermarket changer you will probably have to go with an FM modulator setup.
If you are unsure what will work, crutchfield.com is a good resource for what will fit and how to do it (they will give you general info, but if you buy you get very detailed info on installation that is custom to your year,make,model). For what it is worth, I put an aftermarket head unit into my '96 using a crutchfield install kit and it was very easy.
Old 09-24-2007, 08:13 PM
wiswind wiswind is offline
I have also found that Crutchfield gives SUPER good information.
I installed a CD changer, and it has a FM modulator that connects inline with the antenna.
However, you need to connect to several power points.
I will caution you......inside the console, below the factory radio.....but down near the floor, there is a small box with a wire harness going to it.
This is NOT an amplifier or in ANY WAY related to the vehicle sound system.
THIS IS THE AIRBAG CONTROLLER!!!!!
So you don't want to mess with any wires going to it.....or with the unit.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 10-22-2007, 03:39 PM
thscott thscott is offline
My 99 Windstar came with a factory CD changer. It is located under the driver's seat. Perhaps you'll find a harness there.
