Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-23-2007, 07:59 PM
bsskierfolife bsskierfolife is offline
clutch is acting up
i have a 95 eagle talon awd turbo
an act 2600 clutch and i got the extended slave cylineder rod for it new slave cylinder and new clutch masteer cylinder i think their is some drag in the clutch cause it doesnt like to engage all the way how do u adjust the clutch or clutch pedal cause it only engages half way...
Old 09-23-2007, 08:05 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: clutch is acting up
Do you mean the clutch doesn't dissengage all the way. As in it wont fully release? When the clutch is engaged it is locked in with the flywheel and pressure plate.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-23-2007, 11:09 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
i think he means it sliping... and yes, check out the clutch cable to the master cylinder (from the inside of the car) u can adjust the arm leangth their with a 12mm (IIRC) wrench and channel locks...
Old 10-16-2007, 09:59 PM
mygirlsmylife mygirlsmylife is offline
Send a message via Yahoo to mygirlsmylife
act 2600 is what i ju8st replaced horrrrrrrrrible clutch feel lots of foot pressure but never disengages all the way ever even with an extender rod and adjusting master cyl rod as a matter of fact i even had to create an extenson for that rod nothing works richard at act even admitted that 94 eclipses do not tolerate the 2600 that well the hydraulics cant handle it i just replaced with an exedy, barks all the way to 3rd on factory boost!!!! yes i know yours is a 95 but i have a late model 94 with unfortunately is a 7 bolt F vin 4g63t just like yours i have no crank walk yet!! even though i drive it into the ground with 250000 miles on original engine but this car has nickle and dimed me for 14 years now it sucks but ill kill it before i sell it
