Old 09-23-2007, 02:22 PM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
tranny PROBLEMS?
ok to start ihave a 91 dx 3 door 5spd manual civic one day iwent to down shift to second gear and i got to neutral and the engine died and i could smell burning oil i expected the worst when i got to the side of theroad and tryed to sart the car and go again the speedometer went up but the car didnt move i thought i broke an axle got the car towed home and found the spider gears hanging out of the bottom of the trans and the case was split wide open so i pull the trans out and put in a new clutch assumeing i would have a trans in a week or so well its been over a month i found one and Archies auto parts in merrillville swares up and down it was out of a 91 well i get it almost in and find its not right so i take it back and they dont have a nother one now after 2 hours of fighting with the ahole i got my money back and now i cant find one cheep what is the deal i see theese cars everyware and im not putting 700 bucks in a 900$ car
any help with this would be great thanks for listening and for any help
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 09-23-2007, 03:52 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: tranny PROBLEMS?
Well that was one long sentence.
Why wouldn't the transmission work? Just as long as you get one from a 88-91 it should bolt right up, even the 92+ D-series will bolt up, but those are hydraulic instead of cable.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 09-23-2007, 06:47 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
what was so "wrong" about the new tranny, first off
Old 09-24-2007, 08:25 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Wrong.
88 transmissions are different. They have 21 splines on the input shaft. 89-91 transmissions only have 20. That must have been what the problem was...he must have either sold you an '88 tranny which wouldn't work because you're using the 90-91 clutch style, or you already had an '88 tranny because the previous owner swapped it out or something.
You can use an 88 tranny, but you have to use the 88 clutch. 89-91 has to use the 89-91 clutch. BTW, the 90-91 clutch is slightly larger in diameter than the 89 clutch.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 09-24-2007, 04:29 PM
thank you for saying exactly what I was thinking when I asked
"what exactly was "wrong"
we had that problem on my friend's 4th gen... bought a clutch, and the guy sent a '91 clutch for an '88
Old 09-24-2007, 05:47 PM
Tony's Avatar
TLD Member #1
Whoops, thanks for correcting me BamBam, forgot about that.
Tony
