Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-23-2007, 01:20 PM
crzycooter crzycooter is offline
i have a problem that i just cant figure out
i have a 92 firebird that just all of the sudden shut down. i was told to change the ignition switch but still nothing. the lights work but when u turn the key the is no power from the ignition anybody that could i would greatly appreciate it
Old 09-23-2007, 03:19 PM
sdsniper's Avatar
sdsniper sdsniper is offline
Re: i have a problem that i just cant figure out
Is the starter turning?
Old 09-23-2007, 04:15 PM
CamaroRS92 CamaroRS92 is offline
When you changed out the ignition lock switch did you have the new keys made with the same resistance code as the ECM is set to ?
If not --- you will have to have keys made with the correct code otherwise VATS will shut down everything
