Old 09-23-2007, 10:43 AM
cyberkid's Avatar
cyberkid cyberkid is offline
Plexiglas translation prob
Hey all,
I'm looking to build a display case after reading Alex's tut.
Now, my question is:
Is plexiglas the same stuff used for making those cases on advertising or neon lights?
If anyone here knows is plexiglas 壓克力板?
Does plexiglas hold up to light dusting or cleaning with windex or simular?
TIA for replies.
Steve
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 09-23-2007, 11:25 AM
drunken monkey's Avatar
Razor Sharp Twit
Re: Plexiglas translation prob
plexiglass = perspex = acrylic
AF's Guidelines
Read them.
Old 09-23-2007, 12:09 PM
freakray freakray is offline
AF Modelrater
Plexiglas also gets called lexan sometimes.
AF User Guidelines
Old 09-23-2007, 12:22 PM
klutz_100's Avatar
I think plexiglass also holds static electricity charges like a limpet and therefore might attract a lot of dust
(I may be wrong on this though)
Old 09-23-2007, 02:07 PM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
= methacrylate
gio
Old 09-23-2007, 02:25 PM
klutz_100's Avatar
Originally Posted by gionc
= methacrylate
la la la ...and a partridge in a pear tree.....
Old 09-23-2007, 02:59 PM
matador88's Avatar
matador88 matador88 is offline
plexi and lexan arent the same...
Old 09-23-2007, 03:07 PM
AF Modelrater
You're 100% correct - which is why I can never understand why so many people think they are and hence why I said it sometimes gets called lexan.
AF User Guidelines
Old 09-23-2007, 04:13 PM
gionc's Avatar
Authorized Vendor
They're the same material: ever methacrylate or polycarbonate, only lexan is extruded with air inside (those translucent or trasparent curtain panels, mostly from General Electric) and the plexiglass is laminated in sheets, but the material is the same: also Lexan, Plexiglass and Perspex are just commercial names.
gio
Old 09-24-2007, 06:03 AM
cyberkid's Avatar
Thanks guys for the replies, but not really what I needed.
These brands are scarce here and I'm looking for a tad more confirmation on what it is commonly used for.
My aunt-in-law is a advertisment hardware builder by profession. Making those lamps the swirl in a transparent box..
and the material she uses for the cases is roughly translated into: acrylic board.
If its the same stuff then I'm relieved, if not I want to find some as glass isn't really an ideal option for me (too heavy).
And about cleaning plexiglas (if it is what I know as 'acrylic board'), are there any products other than novus? Will windex and the like work well (mainly without leaving scratches)?
Thanks again,
Steve
Old 09-24-2007, 07:01 AM
Razor Sharp Twit
the thing that makes the most difference is the type of cloth that you use. Hopefully, you have a stash of microfibre cloths to use on models. The surface of the perspex (or what ever you want to call it) is actuallt very hard and usually, only continued exposure to the elements (as you do with greenhouses) and/or hard cleaning with rough cloths will induce swirl marks.
If you're making your own display cases, I should also remind you to use the proper glue. For these things, nothing beats dichloromethane which if you have a model making/design&technology department in your school/college with a decent workshop/studio, they should have.
If not, then look out for something like Plastic Weld which is a diluted form of the stuff.
AF's Guidelines
Read them.
Old 09-24-2007, 09:07 AM
cyberkid's Avatar
Thanks for the info DM, I'm only planning to use the perspex ( dang thing has too many names lol) for the see through glass. The shelving itself will be made of wood simular in Alex's tut.
Regular glass won't reliably hang from small hinges and thin wood, I'm planning to use 2/8" or 3/8". I'll be asking my aunt to see if she can get novus from her supplier.
Old 09-24-2007, 10:54 AM
Razor Sharp Twit
ahhh, right.
my bad.
I assumed you were making individual cases and not a shelving type display. I have to confess to not having clicked the link.
In which case, I'd should remind you that you won't need more than a 3mm sheet (my supplier works in mm) which is about 1/8". 6mm (2/8") is quite heavy, especially if you're going to be using the full 24x12 sheet.
AF's Guidelines
Read them.
Old 09-24-2007, 11:46 AM
cyberkid's Avatar
ahhh, right.
my bad.
lol, my bad this time...
expecting to use a 3 or 4 mm sheet of plexiglas, I'm thinking a sheet of 2mm will look flimsy.
the wood for the shelving itself will be 2-3/8".
I'm actually thinking of making it a tad bigger as I have a few couple 1/12 cars on the way. Maybe 32*16 ish.
But I will be using wall plugs.. the plastic things that you put into walls for you to use screws, so it should be more sturdier than Alex's.
Thanks for the help again everyone. Much appreciated.
Steve
