Old 09-22-2007, 09:11 PM
jcutner jcutner is offline
Primer.
I just got a Tamiya Mitsubish Lancer Evolution VI
This is my first time building a Tamiya.
Body is molded in white, it indicates to paint the bottom part the same colour as the body, and I chose Tamiya Spray Metallic Blue.
However, for my past 4-5 models, I've sprayed them right away. This one really makes me feel that I need primer. I know I *need* it anyways, but I never used it.
I'm just afraid that shooting it with the metallic blue, it may look washed out, if it doesn't hit the body right, as if the paint doesn't stick.
I really suck at doing mist/light coats too, I end up doing a few heavy coats. I need to practice on that.
So I'm sure you would all agree it definitely needs primer. What should I go with? I've heard bad things about the Tamiya Primers from here though...
Any help would be greatly appreciated. Thanks guys.
Old 09-22-2007, 09:33 PM
freakray freakray is offline
AF Modelrater
Re: Primer.
You're heard bad things about Tamiya primers? You're sure?
I can assure you there's nothing wrong with Tamiya primer.
Testors primer on the other hand, treat it like it comes with a free case of the plague.
AF User Guidelines
Old 09-22-2007, 09:54 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Primer.
What Ray sed.
Tamiya grey is what you want.
Try the hot water trick for warming the spray can before you paint. It helps alot with getting good even mist coats.
PHOTOBUCKET SUCKS
Old 09-22-2007, 09:55 PM
360spider's Avatar
Re: Primer.
http://www.italianhorses.net/Tutoria...mer/primer.htm
Old 09-22-2007, 10:03 PM
AF Modelrater
Re: Primer.
Nice tutorial Alex
AF User Guidelines
Old 09-22-2007, 10:21 PM
Re: Primer.
Maybe I'm mixing it up with Tamiya Clearcoat? (also, I've never clearcoated before either )
Old 09-22-2007, 11:31 PM
klutz_100's Avatar
Re: Primer.
Probably you are mixing it up with Tamiya TS-13 clear
Old 09-23-2007, 09:03 AM
MPWR's Avatar
Re: Primer.
Yeah, that's almost definately it.
Tamiya laquer clear (TS-13) is a very good product, but like all laquer clears it requires care and patience to apply properly- spray it too quickly and heavily and it can destroy paint and decals under it.
No worries about the primer, though.
PHOTOBUCKET SUCKS
Old 09-23-2007, 09:45 AM
cyberkid's Avatar
cyberkid cyberkid is offline
Re: Primer.
Tamiya's primer line is great. I also use Gunze's Mr. Surfacer line.
As for the mist light coats... I used to be like that as well... I just couldn't wait to get the thing painted. But, like most other things in life, patience is essential... When I get that feeling that I might have the erge to wet coat it straight away, I mist coat it then put it in my dehydrator and work on something else in the kit.
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
