Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-22-2007, 12:53 PM
Burnindesirez02 Burnindesirez02 is offline
Short Shifter
I got a short shifter for my 1997 Eclipse GST and when i was taking the stock one out a spring popped out of no where and i don't know where it goes...When i am in any gear my shifter seems like it is in neutral so i know that it is for the shifter. Thanks
Old 09-23-2007, 12:55 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Short Shifter
There is a spring in there somewhere, see if this helps. Its the best diagram I could find.
http://alldatapro.com/alldata/PRO~V6...03008/78473738
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-23-2007, 07:44 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: Short Shifter
This is on a 1g, which is a little different, but the concept is still the same. You want to make sure that part of the spring thats sticking up is on the correct side. It should have tension on it. If it's on the wrong side then it won't return to the middle, while in neutral, on its own.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
