| Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models |
Is my engine blown?
My 1998 Olds 88 has a 3.8L. It was running hot and we added water to the radiator while the car was running. Instantly the engine cut off. When trying to restart it sounded like the starter was trying to start the engine but the engine wouldn't turn over. I removed all of the plugs and still will not turn over. Is my engine blown anyone have any sugestions any help I will appreciate. Thanks.
Re: Is my engine blown?
Take the serp belt off and try it. It could be a locked up water pump (this would account for the low coolant level) or other belt driven accessory that isn't allowing the engine to turn over.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
how hot did you get it you might of warped something but i don't see any reason for it to seize unless you have a cracked head but thats just about imposable with the 3.8
1993 Olds 88 112k and counting 81 mile a day daily driver. 2005 Grand Prix 47k weekend car. |
Not sure how hot I wasn't actually driving it the night in question, but I thought it was strange because it overheated on me one time before and the engine stalled because of the sensor that only allows it to get so hot before it shuts down. Does this sound right?
uhhh i dont know much about the series 2 of the engine ask gtpdad or another moderator they know there stuff
If the starter is turning the belt and all of the pulleys are turning, you might have just got a cam sensor or crank sensor that went out. If the cams or crankshaft aren't reading right, the engine won't even spark. If you could get the codes read, that should tell you.
Otherwise, you could just replace them, but as with replacing any part without certainty, you risk that not working and being a needless fix plus money wasted. Replacing both would be about $120 - 150, which is with the sensor and the harmonic balancer puller, which is a tool you'll need. |
check your battery
