Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 09-21-2007, 09:08 PM
vandok13's Avatar
vandok13 vandok13 is offline
Brakes
1988 Toyota 4runner, 22-Re, Automatic
I just did all the brakes, put new fluid in and bled them properly(i think). I thought it was air at first because if i stopped on a hill and kept the pedal down firm the pedal would eventually sink to the floor and then i would have no brakes but if i pumped them they would work fine, the pedal would build up again. Now they only work sometimes like once of of 10 times they work but the pedal goes all the way to the floor, and i cant make them work by pumping the brakes. I just discovered a new stream of brake fluid how ever down my brake booster but my fluid level hasn't dropped noticably since i put the new stuff in. Would it just be the seal between the master and the booster or would it be bypassing something in the master itself????any help would be very much appreciated...thanks in advance
Old 09-21-2007, 10:51 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Brakes
... I just discovered a new stream of brake fluid how ever down my brake booster but my fluid level hasn't dropped noticably since i put the new stuff in. Would it just be the seal between the master and the booster or would it be bypassing something in the master itself????any help would be very much appreciated...thanks in advance
If the brake MC had an internal leak (fairly common) there would be no external leak. If the fluid is leaking inside the truck under the dash, it would be the MC. On the other side of the firewall by the booster, still could be the MC.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 09-22-2007, 12:40 AM
vandok13's Avatar
Re: Brakes
Ok, so do i need a hole new master or can i take the stuff out and replace the seal??
Old 09-25-2007, 07:46 AM
fourwd1's Avatar
AF -Advisor
Re: Brakes
You might be able to get rebuild parts from Toyota, otherwise you'll have to replace the MC.
If you do, make sure to bench bleed it first.
89 4Runner - stock
Old 10-25-2007, 06:55 AM
vandok13's Avatar
Re: Brakes
Got a brand spanking new MC, high quality. go the family discount at a freinds parts store. after instalation my brakes worked wonderfull but maybe a week later i had another stream down my rear tire so i had to replace my brake cylinder. My braking system is perfect now. Almost as good at my 07 tacoma.....not
Old 10-25-2007, 07:37 PM
fourwd1's Avatar
AF -Advisor
Re: Brakes
Glad you got it fixed, brake problems suck.
89 4Runner - stock
