Old 09-21-2007, 07:03 PM
chainman chainman is offline
A/C blower motor intermittant
I have (2) 2001 Cherokees and the blower on one has quit working. I swapped the relay from one to the other.(no fix). Then I swapped the control module still no fix. all swapped parts work fine in the other vehicle. Any help would be appreciated.
Mike
Old 10-23-2007, 01:46 PM
95Jeep00Expedition 95Jeep00Expedition is offline
Re: A/C blower motor intermittant
I've read alot about the wiring getting loose...no reason. Plus it may be worth checking the fuse...often we overlook the easy solution. Me, I start with easy because after that Im out of options. lol
Old 10-23-2007, 09:21 PM
wwwildman wwwildman is offline
Did you check the wiring connectors on the one that did not work?
My 87 did the same thing, and when I pulled the control section out of the dash panel, I noticed that one of the wires had burned and melted. Once I corrected that, the blower works as it should.
Mike
Old 10-29-2007, 12:43 PM
Raimundo Raimundo is offline
Same thing happened to me . Replace the blower motor.Period.. Autozone has it for about $39.00
