Old 09-21-2007, 07:02 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
axle question
drives side front axle has some play in it...when i put the wheel back on and tightened the lug nut i was able to move the wheel back and for, not much, but i think enough so that it's making noise while i drive, any suggestions?
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 09-21-2007, 08:44 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: axle question
You could try and see if the axle nut on the hub is loose, if that's not it, maybe check that the circlip in the tranny side isn't broken... had one break and move around on me, sometimes noise, sometimes not.
Ummm... if it's moving around and you're short on cash, a "one week" solution is to pull the axle from the hub and put a crush (copper) washer behind it, then tighten that nut as tight as you can get it w/o rounding it off... that will stop the noise for the most part, but it's not safe to drive on for a long pd. of time.
Might also consider jacking under the suspension to get it fully compressed, with the tire off the ground, and putting a 5 ft or better bar under the tire, and trying to move it up and down... will usually tell you if you have bad wheel bearings... doesn't always work, but if the tire moves up and down, and it's noticeable, you should pry have new bearings pressed in.
Old 09-21-2007, 09:05 PM
BLU CIVIC's Avatar
調整器
Re: axle question
doesn't move up and down, just in and out...but i will try those in the morning
The name's Adrian
2011 CR-Z - Stock
Old 09-21-2007, 11:08 PM
Re: axle question
the crush washer only works if it's loose in the hub.. if it's axle noise, (actual axle noise) you should pry check the bearings (univ's) in the axle
