Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-21-2007, 05:50 PM
EngineandJuice EngineandJuice is offline
Box Caprice Dual Exhaust pic request
Hi I recently went to a muffler shop and got an estimate on true duals for my 88 caprice. $600 w/o cats is what I'm looking at. They explained that they were gonna do the process where you cut the brace for the transmission and go from there. I noticed while searching the forum that many people have true duals by using the LT1 crossmember and all that. If possible can i get some upclose and personal pics of any true dual exhaust on box caprices. Including ones that have had the brace for the transmission cut. I appreciate any help possible on this matter. I can see the price droppin drastically if I can convince them to use some parts I bring from a junkyard.
Old 09-21-2007, 05:56 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Box Caprice Dual Exhaust pic request
You can use the LT1 crossmember, but only if you weld an extension to the frame on the driver side, behind the current crossmember mount. The LT1 crossmember is too short to otherwise use.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-22-2007, 11:27 AM
deesandvees's Avatar
deesandvees deesandvees is offline
I'm in the same situation EngineAndJuice. So that's two votes for let's see some pics. You got headers?
Old 09-23-2007, 09:11 AM
DANZIGS DANZIGS is offline
I've got an 89 with the single set-up. The cat is hollowed out and I put a Force muffler (generic Flowmaster) on it. I would be happy to find a company that makes a split pipe after the converter to run dual mufflers and tails. Does anybody know of such a part or another vehicle that has that setup so I could interchange the part? I figure some custom exhaust shop could do it but I enjoy doing it myself.
Old 09-23-2007, 12:04 PM
silicon212's Avatar
Confoundingly Lucid
I made my own Y-pipe out of LT1 car exhaust components, and a 45 degree elbow from Autozone. Of course, I have access to a welder, which you will need if you want to do this.
Old 09-23-2007, 06:42 PM
Silicon2, do you have pics? Did you use the tailpipes from a LT1 also? A welder is no problem.
Old 09-23-2007, 07:01 PM
SEVILLEMAN601 SEVILLEMAN601 is offline
EngineandJuice... I know a guy that would do that for only $275 if you stay anywhere by mississippi...
Old 09-24-2007, 10:42 AM
Another question is what about the floor? Looks like it needs to be banged up to make room for the drivers side hump on the LT1 crossmember. I'm guessing it would need to match the passenger side.
Old 09-24-2007, 11:34 AM
silicon212's Avatar
Confoundingly Lucid
Nope - it will clear it fine. The 'hump' is for a catalytic converter. On the LT1 system, the driver side cat sits farther forward than the passenger cat.
Old 09-24-2007, 09:36 PM
These questions are why pics are so important to me. I'm a visual person so seeing it helps alot more than reading it.
Oh and I'm in MD so that $275 is a no go but thanks anyway.
