Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 09-21-2007, 05:57 PM
fanbelt fanbelt is offline
Are there tricks or traps in replacing Cavalier starter?
99 Cavalier
I think 2.2L engine but have to check for sure.
Car was not starting in driveway, I think it is the starter.
Cleaned all the wire connections on the solenoid.
Key in switch, dash lit up, turned to start, one loud click from under hood, everything totally black, dead, and quiet.
Not an experienced repair person. Looks like disconnecting all the wires to the solenoid and removing 3-4 bolts to get starter off, reverse process for new one.
Are there issues in making a new one mesh properly with the flywheel? Are there other issues I should be aware of before attempting the repair myself?
Thanks.
Old 09-21-2007, 06:41 PM
muff34 muff34 is offline
Re: Are there tricks or traps in replacing Cavalier starter?
Check your battery before you pull your starter off. It should be around12.5 volts with the engine off. Also before you pull the starter give it a tap with a bar or hammer then try to start it(you don`t have to beat the crap out of it). if she starts likely the solenoid,then you`ll know it is starter related and it has to come off . I have not pulled one off these engines but have done others ,it is usually pretty straight forward ,no biggy. I`m sure some who has will respond if there are tricks to this model
Life Is A Highway ,Enjoy The Ride
Old 09-25-2007, 05:09 PM
There were some issues.
Old 09-25-2007, 06:36 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
like?
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 01-25-2008, 10:18 PM
anomaly_va_1976 anomaly_va_1976 is offline
I don't know this year specifically... but the older 2.2s had a bracket on the starter to brace it against kicking back and forth, and it must be reinstalled or it will break the bolts over time.. ask me how I know Bracket would be between the starter and the a/c bracket....
Don't Worry What Others Think -
They Don't Do It That Often!
James Collier < [email protected] >
1992 Chevrolet Cavalier Z24 Convertible (3.1, 5-sp) *** FOR SALE -- SEE CAVALIER CLASSIFIEDS ON AUTOMOTIVE FORUMS.COM***
1993 Chevrolet Beretta (3.1, 3-sp auto)
1995 Mercury Marquis (Taxicab, i.e., breadwinner)
Old 01-26-2008, 12:25 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Closed. anomaly_va_1976 doesn't seem to know when to stop bringing up old outdated threads.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Closed Thread
