Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 09-21-2007, 04:31 PM
a_alyte a_alyte is offline
Angry Coolant Leaking Again
'98 JGC
I had this same issue back in '05, coolant leaking from passenger side. When I pop the hood the coolant can be seen puddling just below the drain plug on the radiator, but the drain plug is tight & dry. All hose clamps are tight. When the Jeep is turned off, the coolant drips off the front bumper causing the reservoir to get low after a couple weeks . In '05 I replaced the rad, thermostat, water pump & hoses. It was good for a while but here I am again with the same issue.
Anyone dealing/dealt with this?
Old 09-21-2007, 04:36 PM
dell520's Avatar
dell520 dell520 is offline
Send a message via Yahoo to dell520
Re: Coolant Leaking Again
I am. I don't have any idea where the leak is, but it's very slow so I havn't put much time into it just because I plan on doing a swap soon when I put the electric fan in.
Hope someone can help ya.
Old 09-24-2007, 03:22 AM
Bob D. Bob D. is offline
Use a pressure tester to pressurize the radiator and look for the leak.
Old 09-24-2007, 06:03 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
It is probably leaking from the seam where the radiator core and side tanks meet.
I had this problem with a couple radiator along with the new one I just replaced back in march, getting ready to send it back for a new one under warranty
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 09-26-2007, 01:10 AM
If my leak is coming from the seam as you described, is there something that can be moved or bent out of the way when installing a new rad to prevent it from reoccurring?
Old 09-26-2007, 07:27 AM
I don't know what you could do better other than be reasonably careful - when it's in the vehicle it takes a pretty good pounding.
As dksob81 said, the side seams are where they usually leak, but I cant believe you guys are having such bad luck. Are they OEM or aftermarket?
Old 09-26-2007, 11:59 AM
The 1st one I put in was OEM & the one leaking now is aftermarket. In my Jeep they seem to leak every 2 yrs.
