Old 09-21-2007, 02:43 PM
DRUSS1999 DRUSS1999 is offline
04 Grand Prix HUD issue
The Electronic HUD speedometer (that shows up on the windshield) suddenly is just out of my view. I use the arrows to move it up or down and it will not move. Does anyone have any ideas before I call the dealership? Thanks
Old 09-21-2007, 02:59 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 04 Grand Prix HUD issue
Check the connection at the switch, if that checks out, you'll probably have to have the dealer look into it.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-27-2007, 11:51 PM
Wired_78 Wired_78 is offline
I had this problem, but was able to fix it. The problem with my HUD was broken plastic in the HUD that was holding the adjusting spring. I was only able to see the HUD between the dash and upper portion of the steering wheel. I was able to take the dash apart, remove the HUD, drill a new hole for the spring, and replace the hud in a few hours.
If you look in the front left of the HUD from outside of the car, you can see the spring. Wiggle the car and see if the spring moves.
