Old 09-21-2007, 02:43 PM
BLWHITE BLWHITE is offline
Send a message via Yahoo to BLWHITE
Wink Timing
I Want To Know If Anyone Knows What The Ignition Timing Should Be Set At Also What The Rpm Should Be Set At, 1991 S-10 4.3 Engine
Old 09-21-2007, 07:56 PM
old_master's Avatar
Advisor/Moderator
Re: Timing
With the EST (Electronic Spark Timing) wire disconnected, (located under the dash behind the carpet above passengers feet, brown single wire) timing should be 10 degrees BTDC (Before Top Dead Center). Idle should be around 650 RPM in drive. Should be a white sticker under the hood with the specs on it.
Old 09-22-2007, 10:28 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: Timing
Although idle can technically be adjusted on this, there really shouldn't be any idle adjustment needed. As for the timing, old_master, I'll correct ya, as I hope you do same for me, but its at "0" with the EST disconnected.
Old 09-22-2007, 10:33 PM
old_master's Avatar
Advisor/Moderator
Re: Timing
I stand corrected. Good call, thanks!
