Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 09-21-2007, 11:30 AM
mporetti mporetti is offline
2004 545 rattle in sunroof
Whenever I open the sunroof I get a slight rattle when going over rough pavement...
Is there something that can be adjusted to correct this?
Old 09-21-2007, 11:06 PM
sidewinder69's Avatar
sidewinder69 sidewinder69 is offline
Re: 2004 545 rattle in sunroof
Anyone else want to say the obvious?
I guess you could pull down your entire headliner up to the sunroof and see if anything is loose. Try opening it partway and check the arms that hold the sunroof up, there could be a loose bolt.
Now do you mean when you slide it back all the way? Or when you just have it tilt up. Cause mine has been doing the same thing, I just let it go all the way to the back and then I just nudge it forward and the rattle goes away.
Aren't you that kid my older brother used to throw dog shit at?
Beamer:
http://www.facebook.com/album.php?ai...4&id=761900240
Old 09-27-2007, 09:57 AM
I have had two 2004 545i's both had the rattle...I suspect it is a cable that is not tight. I thought it might have something to do with the manual closure crank in the trunk...
your idea of a nugde forward would like pull the cable tight and stop the rattle.
