Old 09-21-2007, 06:45 AM
The Crew The Crew is offline
Question Water in my Caravan
97 Grand Caravan SE (AWD), 135,000 miles, 3.8L V6 MFI. Recent servicing includes New Transmission, new radiator, new water pump, new brake lines, new A/C compressor, new starter, new tires, oil change less than 1500 miles, air filter and plugs.
I have water leaking into the front passenger compartment (Drivers side is dry). It is not just a little water, it is a healthy stream that soaks the entire passenger compartment carpet. I found that the "water tray" underneath the windshield was clogged with leaves and dirt. Cleaned and flushed the tray and drain lines. I am still getting water in the van. Everytime I hit the brakes or go down a hill, water starts running down the front passenger floor board. It seems to be coming from the heater box. I am wondering if there is a fresh-air vent/door in there somewhere that could be stuck open or if there is some kind of air intake for the A/C and heating sytem that is letting the water in and if so where do I start looking? Do I have to take the heater box completely out? Do I have to remove the dash? What is the best way to approach this problem.
Old 09-21-2007, 10:33 AM
taillight taillight is offline
Re: Water in my Caravan
Sounds like the drain for the A/C evapotator is cloged. Look on the firewall engine side passenger for the outlet.
Old 09-22-2007, 06:16 PM
hundahunta hundahunta is offline
there is a tsb to install a evap drain tube also reseal the tube area with rtv to ensure
Old 09-24-2007, 09:38 AM
jerryls jerryls is offline
I had the same problem with my 97 T&C. There is a drain hose that gets clogged. It runs down from the wiper area to under the car on the passenger side. Clean it out with a wire hanger from the bottom.
Old 09-24-2007, 08:06 PM
After looking at mine today, I realize I was thinking of a different car(above). The T&C lines don't go all the way to the bottom, they dead end on a chassis rail. To clean them just pull them off under the wiper cowl area and run water through them with a hose to make sure they are not clogged.
