Old 09-21-2007, 12:38 AM
wizzard1222 wizzard1222 is offline
87 LeSabre IGNITION will not turn to the ON position
87 LaSaber key ignition will not turn to the On position. It will turn backward to the acc position. Turned the sterring wheel and pushed the brakes while trying to move the gear shift lever to engage the key forward movement. Nothing is making the key to operate normally. I have had some rough times in the past to get the key to move forward to the On position. I am thinking that the key (ignition) is just broken or out of tolerance from usage (170,000 miles and age). Your assistance is appreciated.
If this is the problem, can the parts be removed and new parts installed easily?
Old 09-21-2007, 04:27 AM
maxwedge maxwedge is offline
A990 racer
Re: 87 LaSaber IGNITION will not turn to the ON position
Welcome to AF, no quick answer here take it apart and see whats what, could be the key mechanism, the or the ign switch itself.
Old 09-21-2007, 07:59 AM
If if is not the Key mechanics, where would I find the IGNITION SWITCH? What does it look like? I have chased down the hazard and turn signal relays under the dashboard covers before...is the ignition switch down in that area as well?
Regards and thanks
Old 11-01-2007, 01:11 AM
georgiaboy107 georgiaboy107 is offline
Re: 87 LeSabre IGNITION will not turn to the ON position
replace the lock cylinder. you will need a steering wheel puller, and a lock plate remover. A haynes or chilton manual will help. I have a 1989 Buick Lesabre, 246,000 miles. I had the same problem and replacing the lock cylinder solved my problem.
