Old 09-20-2007, 11:43 PM
biodan955 biodan955 is offline
Fuel Bleeding Down in Fuel Rail Quickly
I have a 2002 Intrigue (3.5L) where the fuel pressure bleeds down to zero approximately 10 seconds after the ignition is turned off. I already replaced the fuel pressure regulator (it had fuel in the vent tube). It started perfectly for one week after FPR replacement, then problem returned. Once car starts, it runs perfectly, but it is very difficult to start if it has been sitting a while. My question is, what holds the fuel pressure in the fuel rail? Could the new fuel pressure regulator have gone bad after one week? Could a defective fuel pump allow fuel to bleed back into the gas tank and cause the fuel rail pressure to drop to zero? I no longer have fuel in the vent line of the FPR, but the pressure at the Shrader valve drops rapidly after the key is turned off. Any advice would be appreciated.
Old 09-21-2007, 03:45 PM
maxwedge maxwedge is offline
A990 racer
Re: Fuel Bleeding Down in Fuel Rail Quickly
Leaking injector is a possibility here.
Old 09-23-2007, 12:08 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
You could pull the fuel rail and check that the injectors arent leaking.
You could also pull the spark plugs and see if any of them are fouled from sitting in fuel from a leaking injector. Unless this has been occuring for a while, or occurs often though, they might not be fouled up bad.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 09-26-2007, 07:45 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
I'm not sure about GM pumps, but most of the German cars with Bosch pumps I've worked on had a check valve at the fuel pump. I would assume GM may have something similar.
2003 Pontiac Grand Prix 3.8 Litre V6
ASE Certified Master Tech
Old 09-26-2007, 09:12 PM
LittleHoov's Avatar
I believe you are correct in assuming that. Thats another good reason to allow a couple seconds of having the key in the "ON" position to allow pressure to build up.
