Old 09-20-2007, 08:48 PM
ozzfreak ozzfreak is offline
Possible to clean the ignition switch?
I have a bad contact going on in my ignition switch, and when I turn the key, sometimes it will start right up, other times I really gotta twist it, and I'm scared I'm going to end up breaking the key off. Is there a way to clean the contacts in there, or is my only option to just replace it? Thanks.
Old 09-20-2007, 09:49 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Re: Possible to clean the ignition switch?
I'd just go ahead and replace it, the part itself will cost around $75 from a Honda dealership.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 09-20-2007, 11:43 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
did you check the back of the ignition switch? take the back off and see if its just that part messing up, or if its loose. You could probably pick that piece up fairly cheap at a salvage yard, just find a car that doesn't have a key that way they can't charge you for the whole switch.
Just sounds to me like its the back piece that is messing up. This will let you keep your current key and save you the hassle of taking the whole thing off...hopefully, haven't looked at the back to see how tight of a fit it is. It is usually 1 or 2 small screws holding it on.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 11-08-2007, 08:31 PM
Ranscat Ranscat is offline
I replaced 3 ignitions in my civic, thinking that they were sticking or going bad. I finally got smart and realized that it was just build up on the contact tabs in my distributer. Once or twice a year cleaning the tabs with a wire brush kept it starting every time and avoided a costly replacement.
Old 11-09-2007, 01:47 AM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
He's not having that problem... his problem is that the engine won't crank, if I got it right... this is caused by two things in the key switch
1) bad/dirty/corroded contacts.. don't bother cleaning them, just get a new switch block from a junkyard. or
2) intermittent contact, usually caused by the above... again, replace the switch module.
If this doesn't fix it, try checking your starter solenoid... good chance the lil single wire is loose/dirty/corroded, causing intermittent circuit breaking.. this is another common culprit for this type of problem, as that wire just uses a spade type connector to plug into the solenoid, and it controls when the solenoid draws power from the battery to engage... see how this could be a problem?
