Old 09-20-2007, 07:43 PM
scottsales scottsales is offline
blazer misfire
1998 blazer misfire cyl 1 and 3 consistantly. new plugs wires cap. snap on scanner shows 1 and 3 on misfire.
Old 09-20-2007, 08:06 PM
rhandwor rhandwor is offline
Re: blazer misfire
Use a noid light and check for power to the injectors. Use a stethoscope and listen a bad injector you should be able to hear.
If this doesn't work check compression in the cylinder.
Old 09-20-2007, 09:00 PM
old_master's Avatar
Advisor/Moderator
Re: blazer misfire
Check firing order on the cap. Wires 1 & 3 may be transposed. Try switching them in the cap.
Old 09-21-2007, 04:28 PM
534BC 534BC is offline
Re: blazer misfire
1 and 3 are together on intake?
Old 09-21-2007, 05:21 PM
old_master's Avatar
Advisor/Moderator
Re: blazer misfire
Cylinders 1 and 3 are next to each other physically, both on the engine and in the distributor cap, but not in the firing order.
When replacing the wires, or the cap, it's easy to get confused and install them backwards.
