Old 09-20-2007, 02:24 PM
quickywd01 quickywd01 is offline
Front Rotors
Does the 1997 ford escort lx wagon have 10 1/4" rotors in the front or are they 9" rotors?
Nissan, Subi, Yoter, Ford
Old 09-20-2007, 04:53 PM
jakes1990454ss jakes1990454ss is offline
Re: 97 Escort Brakes
Also, you may want to see if the rear drums need to be adjusted. In time they will wear and the drum will as will. Most calipers, if not all have self adjusting pins. Most rotors aren't afforded with this luxury so they need to be adjusted to make up for the wear every once in a while.
Old 09-20-2007, 05:08 PM
Re: Front Rotors
Does anyone know the size of the OEM brakes on the escort?
Old 09-20-2007, 10:01 PM
Re: Front Rotors
Does anyone know what's the difference between the two front brake disc sizes that are available? I bought the 10 1/4" ones for my '97 escort lx wagon but I'm thinking that maybe the 9" ones were the correct size and that the huge 10" ones were for the zx2 or something.
Old 09-21-2007, 01:44 AM
Torch Torch is offline
Re: Escort Brakes
Pull your wheel off, get a ruler or a tape measure and measure them, quick and easy shouldn't take more than 10 minutes to do.
Old 09-21-2007, 11:30 AM
Re: Escort Brakes
If I was going to do all that I could just call the stealership. Thanks for your help.
Old 09-22-2007, 01:28 AM
Re: Escort Brakes
You're welcome.
I don't understand what is so hard about spending 5 to 10 minutes pulling your wheel off to make sure that you get the correct part for your car, sometimes that is the only way to make sure you get what you need.
Old 09-22-2007, 05:05 PM
Davescort97 Davescort97 is offline
Escort guy
Re: Escort Brakes
[quote=Torch]You're welcome.
Hey Torch. If a person doesn't want to accept any advice, he shouldn't ask for it. Write it off.
Old 09-23-2007, 09:26 AM
Rickottman Rickottman is offline
Send a message via AIM to Rickottman
on the drums on escorts 97-01 the drums do not have star adjusters like your normal drum brakes. the brakes adjust themselves when the shoes are pressed out .
Ricky Ottman
ASE CERTIFIED
Brakes And ABS
Suspension and Steering
Monro Muffler automotive tech
Old 09-23-2007, 06:00 PM
Re: Escort Brakes
Written off...
