Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 09-20-2007, 04:15 PM
2000DodgeNeon01 2000DodgeNeon01 is offline
Wont Start in Park Will Start in Drive
So my Neon will not start while it is in PARK. If its in NUETRAL Im able to start the Neon and drive it. Any ideas what could be the problem?
Thanks in advance.
2000 Dodge Neon
Old 09-20-2007, 07:52 PM
denisond3 denisond3 is offline
Re: Wont Start in Park Will Start in Drive
My Noen is a 97, so may be a little different from yours. But there has to be a switch on/in the transmission called the 'neutral safety switch'. Its job is let the starter work when the tranny is in park or neutral. If the shifter cable is out of adjustment, it could be the shift lever says you are in park, but the 'neutral safety switch' isnt closed because the shifter cable is out of adjustment. The 'shifter cable' adjustment on mine isnt hard to do - once the battery and the battery tray and a few other things are out of the way!
Try wiggling the shift lever in park, and see if that lets it start; its one sign the shifter cable is out of adjustment, or that the switch is just going bad.
Old 09-21-2007, 02:53 PM
Thanks. I have a park/neutral switch on order and should be replacing it this sunday. I'll let you know if it worked.
Old 09-22-2007, 05:15 PM
I replaced the Neutral/Start position switch and that didn't fix the problem. I guess my next try will be checking the shifter adjustment.
Old 09-28-2007, 03:29 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
hmm.. thats weird. the nss should have solved the problme..i cant think of anything else that wouldnt let it start in p, but start in N..
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
