Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-20-2007, 03:58 PM
gunne gunne is offline
Help Please
Hi guys. I’m getting ready to rebuild my motor in my 1996 Eagle Talon TSI AWD auto transmission...ran into a little problem wondering if anyone had some words of advice.
I’m in the middle of trying to pull the motor and having a little trouble. I have already undone all the bolts connecting the engine to the transmission, taken off the transfer case, and undone the motor mount by the pulleys on the driver’s side. Dose anyone has any tricks on how to get the engine and transmission separated? Hell I have also undone the transmission mounts in an attempt to take the transmission out with it....don’t want to test that weight on my rafters.
I do have experience doing this type of work. All where on trucks and seemed a lot easier undo the engine from the transmission. So I’m not completely new to this but have never run into this problem before.
Thank you in advance for your advice.
Old 09-20-2007, 04:18 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Help Please
You need to support your tranny from the bottom, then you might have to carefully pry them about, Dont jam a crow bar in at the edge of the tranny. Find something on the outside you can use to push against. It shouldn't take alot of force. Make sure the tranny and motor are supported bc when you slid that input shaft out the motor you dont want the tranny to drop.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-20-2007, 05:29 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Help Please
There isn't enough clearance to pull the motor off the tranny input shaft without pulling or dropping the tranny too. At least I couldn't get enough clearance when I did mine. It's certainly a lot easier to just pull it all as one unit and put it back in as one unit too... You might as well now that you've made it this far with unbolting everything... Drop the cross member under the tranny, disconnect the rear and front motor mounts and put a few bolts back in to reconnect the tranny to the motor and pull it all out. You will have to drop the tranny side really low and lift the motor side high and at an angle in order to clear everything... Hope that helps some...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-20-2007, 10:30 PM
Re: Help Please
ok, crowbar idead dident really pan out. The droping it out of the bottom is an awsome idea and seems to be working out great, thanks! Just one thing, this is my first front wheel drive auto tranny ive taken out. How the hell do you get the axles out of the tranny?
Thanks for the info
Old 09-20-2007, 11:29 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Help Please
Not true. When I pulled my blown motor from the purple car I left the tranny in solely becaue I had no means to get the spindle unbolted from the struts. If I couldnt unbolt that, I had no way to get the axles out and so no way to get the tranny out. What you have to do is support the tranny from underneath with a jack and get a cherry picker on the motor. Then unbolt all the mounts (I took the whole tranny mount off) and unbolt the tranny. Getting it separated definately took some creativity, I think you ought to be fine with a screwdriver and a crow bar. Once you get it separated, you will need to push/pull the tranny as far over as possible in the engine bay. Then it will take some jockey-ing but you will be able to get the motor out after that.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-21-2007, 01:07 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Help Please
Okay I just got home from the bar, but regardless....WHAT THE FUCK ARE YOU GUYS TALKING ABOUT????? I pulled the motor out of my 95 TSI AWD in 3 hours with no previous experience of dealing with the 4g63. Disconnect all the lines from the motor, unbolt the tranny from the motor (don't forget the flywheel bolts), unbolt the motor from the motor mounts, and don't forget to unbolt the axle support from the back of the block. Other than that, it should come out with a little bit of TLC. Don't try to rip it out with the cherrypicker, otherwise you'll ruin shit, just pull it out nice and easy and it should come smoothly.
95 Talon TSI AWD
97 Eclipse GST
Old 09-21-2007, 01:18 AM
Thor06's Avatar
Jizzed In My Pants
Re: Help Please
^^ Taking the clutch/flywheel off is unnecessay as well, I got mine out with that stuff still on.
Old 09-21-2007, 01:32 AM
Re: Help Please
He said it's an auto, you have to unbolt the torque converter from the flywheel, you can't get it out if you don't.
95 Talon TSI AWD
97 Eclipse GST
Old 09-21-2007, 01:55 AM
caniborrow50cnts's Avatar
caniborrow50cnts caniborrow50cnts is offline
Send a message via AIM to caniborrow50cnts
Re: Help Please
make sure you have it in neutral, it helps work it loose. starter has to be taken off, i believe it is 4 bolts on that model. exhaust has to be taken off along with the 5 bolts holding on the transfer case. both cv axles have to be clear of the tranny. there are two bolts on top of the tranny, one on the front, and one facing the opposite way in the back. very important, take the splash shield off the bottom also. ive seen to many attepts to pull the tranny of with the splash shield holding it on. as far as unbolting the torque converter, not required but makes it 12 times easier to pull out. this method works because i did it about 3 hours ago on mine, except mine is a 5 speed, but i had done it many times on that 92 talon auto i owned.
72 Beetle - trashed
88 Escort EXP - dumped
92 Talon - sold
97 Eclipse RS - still own
99 Eclipse GST - still tearing up the asphalt
Old 09-21-2007, 06:42 AM
Re: Help Please
I donno what ya'll are smoking, but it is definitely easier to pull the motor and tranny out together IMO...
As for getting the axles out of the tranny... There are snap rings on them and you have to wedge a crowbar/prybar between the tranny and the green part of the axle and then give it a blunt hit to pop them out... Unless somebody has an easier way of doing that too...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-21-2007, 04:12 PM
Re: Help Please
Ok prybar is working out wonderfully, have the axle out of the transmission on the pasengers side, little confused on the drivers side. Here is what im seeing. Any help would be appreashated.
Now is the axle going to come out at the #1 position like im thinking is should but not exactly seeing how to pry it out. Or is it comming appart at the #2 because there is a green part like blackcrow mentioned.
Old 09-21-2007, 06:14 PM
Re: Help Please
It will come out at the 1st position... Just grab a hold of the solid part of the axle and give it a hard tug and it should pop out... Of course make sure the carrier bearing (the other side of the green section) is unbolted from the back of the block before trying to pull the axle out of the tranny. lol
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-21-2007, 10:46 PM
Re: Help Please
the drivers side just falls out when you take the two bolts holding the axle on, take the other side out of the wheel hub. it actually seperates in the middle, where it pivots. if you pry between the green thing and the mounting bracket. careful not to bust the seal. taking the engine out will take many more hours but in most cases, if you are doing major work to the engine, it is easier to take the tranny out by itself...if you got air tools, you can have it out in about 5 hours no prob
72 Beetle - trashed
92 Talon - sold
Old 09-22-2007, 11:20 AM
Re: Help Please
Geez, ya'll slack on pulling a motor... I pulled my motor and tranny as one in about 2 hours... Of course I was pissed off at the time too... lol
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-22-2007, 01:43 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: Help Please
Yeah why the fuck are you disconnecting the tranny? I pulled my motor in one day never having done it before.
Just pull the whole thing out from the top if you have a crane or drop it through the bottom.
1991 GSX 2.3 Stroker
