Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 09-20-2007, 07:59 AM
tupac__ tupac__ is offline
engine turn but won't start
old ciera sl 3.3 v6 with 4T40 trans (100 000 miles)
Need direction
I have spark
New coil, cables and etc...
My engine is turning when I tries to start it but wont start at all.
All my fuses have been checked
What could it be: gasoline, other sensor ...
need help
Old 09-20-2007, 11:59 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: engine turn but won't start
check the fuel pressure and see if its getting fuel.
Do you hear the fuel pump run when you turn the key on ?
1999 Grand Am SS 3.4 OHV
Old 09-20-2007, 08:25 PM
yes I can heard the fuel pump running. I already change my fuel filter. Is there a sensor or module relating to the injectors
thanks
Old 09-21-2007, 10:13 AM
Thiers a fuse for the injectors.
Fuel pressure regulator on the fuel rail too,
that's why I suggested getting the fuel pressure checked.
Old 10-05-2007, 03:07 PM
Arinath Arinath is offline
I had a similar issue on my 92 cutlass supreme...
Drove me slightly crazy for a bit.
Now, I'm assuming this is a similar setup on the motor, so I MAY be wrong,
but the problem, in my case, turned out not to be the coil packs or anything like that. UNDER the coil packs, there is a panel that they all plug into.
this is known as the "Coil Module" and that is what turned out to be bad.
I replaced that component, and everything was fine.
hope it helps.
