Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 09-19-2007, 08:46 PM
93SHOcarguy 93SHOcarguy is offline
94 STS Rough Idle
Recently purchased a very nice 94 STS. Has approx 155k. I was very impressed with the interior/exterior condition or I probably wouldn't have purchased one with as many miles. Anyway...The car seems to idle rough when sitting at a stop sign/light when it's in gear. I don't notice it near as much when in park. It doesn't seem to hesitate under acceleration and runs/drives great other than at idle. I replaced the plugs with the Delco OEM style plugs and am still having the issue. No check engine light is on. Any ideas???
Old 09-20-2007, 05:16 PM
DFBonnett DFBonnett is offline
Re: 94 STS Rough Idle
Unless you have a maintenance history that would indicate otherwise, the next logical step, at 155K, would be to replace the plug wires. You can try to mist the wires with water in darkness looking for arcing but that will not reveal everything.
Old 09-21-2007, 07:31 PM
caddydaddy caddydaddy is offline
I'd also give the throttle body a good cleaning.
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
Old 09-25-2007, 09:53 PM
ISmellRubber's Avatar
ISmellRubber ISmellRubber is offline
The other thing that I would look at is the coil packs near the fire wall. Like with some of the v-6 that use the same DIS units and mounting, if one of the coil packs is loose it can mess with your idle as well( remeber this is still a waste spark system like what they used for 3.1, 3.4, 3.8 and the 4.6L) I have seen MANY idle and rough running issues overlooked by seasoned mechanics that just over look this simple fix.
