Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-19-2007, 06:01 PM
qwerll qwerll is offline
Re: Buying a turbo...need advice
I NEED HELP PLEASE!!!, i fried my battery by hooking up the wrong poles together ( negative with positive and positive with negative) and my car wouldnt start after that, does anyone know what could have happened? please i need ur help thankyou
Old 09-19-2007, 06:42 PM
nofear39427 nofear39427 is offline
Send a message via Yahoo to nofear39427
Dude you probally just fried some fuses or possibly a relay.
Check all your fuses and relays for burnt connections.
You could have also fried the battery doing that be more careful
next time.
BTW this is a PERFORMANCE SECTION....DO NOT POST PROBLEMS
IN THIS THREAD there is a problem diagnosis section on the forum.
You will learn that really quick like I did.
Old 09-19-2007, 06:43 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Well that was random as hell. Try making your own post on this, that way you will have more people reading about your problem, and they would be more inclined to help. It'd probably be a good idea to include year make model of your car too.
As for your problem, did you try replacing the battery? Do you see or smell any melted wires? Hopefully no ecu damage occurred, but you won't know that until you get a fresh battery in and try to crank it up.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 09-19-2007, 06:48 PM
ye thanks mayn, but i changed the battery and got it charged, nd i tried to boost it again whn i got back from getting it charged but the car wouldnt start, you dont think it could have fried my cars computer do u?
Old 09-19-2007, 07:20 PM
Really, I would do what was previously said by nofear. Check fuses and relays. If all of your wiring looks good, and you have a brand new battery (with tight connections) then i would start searching for an ecu to swap. Still no clue on the year make and model though.
94 Talon 1.8L-SOLD
Old 09-19-2007, 07:27 PM
alright sounds good, and its a 93 honda civic ex, do you think i should just take it to the mechanic and ask him to check everything and bring a new battery for him to check if it is just that or if i need a new ecu
Old 09-19-2007, 07:46 PM
Oh i thought you said you already tried a brand new battery. That would be my first guess. If you don't feel comfortable with doing the work yourself, take it to a mechanic. Chances are its not the ecu, but you won't know until everything else has been checked. Always replace the cheapest parts first.
94 Talon 1.8L-SOLD
Old 09-19-2007, 08:54 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Um.... I feel a little violated here. Please start you own thread. Turbo... Battery...? I don't see the similiarity here.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 09-19-2007, 09:04 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Car wont start, help!
Yes, I am that amazing.
Just be sure to read the rules ok?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
