Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-19-2007, 06:10 PM
qwerll qwerll is offline
Fried my car battery while giving boost
ok, i drive a 93 honda civic ex, my car died so i had to give it a boost. I accidently hooked up the negative pole with the positive and tried to give it a boost, nothing happened so i realized i had made the mistake. The day after i took the battery to a shop and got it charged up, i brought it home and tried to boost up my car again, and again nothing happened. Could someone please help me thankyou.
Old 09-19-2007, 06:25 PM
steviek's Avatar
steviek steviek is offline
Re: Fried my car battery while giving boost
does anything work? like interior lights etc?
most likely a fuse or relay, they put them in the car for things exactly like this
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 09-19-2007, 06:30 PM
nothing works, the cars completely dead
Old 09-19-2007, 06:41 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Check all of your fuses in your car. You might have messed up the battery.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-19-2007, 06:43 PM
alright. thanks mayn
Old 09-19-2007, 07:24 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Battery is toast. You'll be lucky if that was all you did too. Being a 93, it probably doesn't have any type of protection against that, so you might have fried a shitload of fuses/relays and possibly the ECU/TCU.
95 Talon TSI AWD
97 Eclipse GST
Old 09-19-2007, 08:08 PM
what do you think the chances are of it having fried my ecu
Old 09-19-2007, 08:21 PM
How long was it hooked up backwards? The longer the worse it is for the car.
95 Talon TSI AWD
97 Eclipse GST
Old 09-19-2007, 10:15 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I just touched the wrong ones twice and nothing bad happened to either of the Talons I was jumping (my purple one and the black parts car before it became a parts car) or the donor car (my Cavy). On 1g DSMs there is a fuse that keeps the overall output below 80A and my guess is you just popped that. I would be hardpressed to believe that. Was the battery in the car when you did this in like a jump situation or was it on a charger?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-20-2007, 01:29 PM
caniborrow50cnts's Avatar
caniborrow50cnts caniborrow50cnts is offline
Send a message via AIM to caniborrow50cnts
battery on your car likely toasted, alternator fuse might be gone.
Considering this is like the 10th post in this thread...
Why don't you check out the civic page and see if they have additional info. While the issue is general, the fix is quite different.
I only have experience with that car because my brother owned two of them, and doesnt know how to fix things. If you jumped it backwards, the battery will almost always be fried. It will usually come up as a dead cell or short cell at first, then nothing. If absolutly nothing comes on, its the battery. The computer has nothing to do with the interior lights, dash, or starter. The starter will still turn provided it had power from the battery. The computer is not likely to be shot since thats what fuses are for. See if you can disconnect the battery, then using jumper cables, connect it to a fully charged battery somewhere. if the car starts and stays running after the cable is disconnected, the alternator is still good. if it dies immediately upon disconnection, the alternator fuse or alternator itself is gone. if nothing happens when you connect a different fully charged battery, you might have melted some very important wires.
72 Beetle - trashed
88 Escort EXP - dumped
92 Talon - sold
97 Eclipse RS - still own
99 Eclipse GST - still tearing up the asphalt
