Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 09-19-2007, 05:07 PM
nascarman70 nascarman70 is offline
Red face 99 Sportage Tranny
Problem i'm having is tranny will shift fine 1st to 2nd but 2nd to 3rd won't shift until car hits a certain temp( first mark on temp gauge).
Old 09-20-2007, 06:18 PM
hvac1000 hvac1000 is offline
Re: 99 Sportage Tranny
This is somewhat normal. The temp sensor out near the top engine hose inlet mounted on the motor has 2 or 3 sensors. One of the sensors tells the transmission not to shift to high gear until the engine reaches a certin temperature is reached. Your sensor has probably gone out of ranger and is defective not allowing the signal to go to the transmission soon enough.
Old 09-30-2007, 06:48 AM
would this be the sensor thats on the hose inlet neck thats goes into the timing cover???
Old 10-18-2007, 01:24 AM
alaskabigdog alaskabigdog is offline
As you are looking at the front of the motor, the sensor that controls that function is the one on the drivers side of the t-stat housing, the one on the passengers side controls the temperature gauge in the instrument cluster.
