Old 09-19-2007, 11:34 AM
dawnr217 dawnr217 is offline
Lifter Problems
We have a 99 Bravada and when you start it up the engine clicks. Was told it was a lifter that is stuck and to just put some Marvelous Mystery Oil in and it will be fine. That did not work and I would like to know what I need to do to get this fixed. Any suggestions would help greatly. We gave the car to my daughter and would like to see it last at least another year. Help Please.
Old 09-19-2007, 11:45 AM
taillight taillight is offline
Re: Lifter Problems
Put an oil pressure guage on the engine and see what the oil pressure is.
Old 09-19-2007, 06:10 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Lifter Problems
My '97 did the same thing when the mornings got cold, the colder old oil must've thickened up. An oil (10W-30 in Tenn., further north may need 5W-30) and filter change was always due about that time too and quieted that lifter right down.
Old 09-20-2007, 06:21 AM
Re: Lifter Problems
Oil pressure is fine. We had the oil and filter changed about 2500 miles ago. We have it done every 5000 miles. What else can I do? Should I go ahead and have the oil and filter changed now and use a different oil?
Old 09-20-2007, 07:13 AM
Re: Lifter Problems
Like Chris said if you are not using 5W30 try it.
Old 10-04-2007, 05:13 PM
scheds41 scheds41 is offline
Re: Lifter Problems
I have a 00 with the same prpoblem, but it sounds more like a knock than a lifter tick. It goes away within the first 2 - 3 minutes of driving. And it only happens when the weather gets cooler. I was told it's a fairly common problem on the Bravada, and that as long as the sound goes away, not to worry about it much. Just keep changing the oil regularly and use the lowest weight oil recommended for that vehicle.
Old 10-04-2007, 05:18 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Lifter Problems
Are you guys using Fram oil filters?
Old 10-04-2007, 06:10 PM
AF - Advisor
Re: Lifter Problems
Never!
AC Delco in the gassers and Purolater Micronic in the Cummins.
Old 10-05-2007, 02:03 PM
Re: Lifter Problems
Yes, I use Fram 95% of the time.
Old 10-05-2007, 09:27 PM
old_master's Avatar
Advisor/Moderator
Re: Lifter Problems
Stop using Fram and you'll have 95% fewer problems!
Old 10-06-2007, 07:25 PM
matt_o_70 matt_o_70 is offline
Re: Lifter Problems
before you get too worried I'd change the oil. I have a 2000 that when the oil starts to break down the lifters start to click at startup, changing the oil always makes her silent again.
This seems to be an issue with hydraulic lifters. I am not a big fan of hydraulic lifters!
Old 10-08-2007, 10:54 AM
Re: Lifter Problems
I had heard that before, but not sure where. It's about time for an oil change, so I'll take your advice. I know I have a lot of milesa dn that has something to do with it too. 193k Runs great except for the tick/knock at startup sometimes.
Thanks to all,
