Old 09-19-2007, 11:33 AM
mmead69 mmead69 is offline
99 Silverado Window Motor
Does anybody know if I can change just the window motor in my 99 silverado or do I have to replace everything. Thanks.
Old 09-19-2007, 12:48 PM
car gal car gal is offline
Re: 99 Silverado Window Motor
You should be able just to replace the motor.
Old 09-20-2007, 08:35 PM
molsonbrador molsonbrador is offline
you might find that the cable has snapped or become badly frayed. i was told that the whole thing is an assembly, kind of like a fishing reel and line.
Old 09-20-2007, 08:53 PM
2string 2string is offline
I changed just the motor in my 03.
Old 09-20-2007, 09:08 PM
vortecman's Avatar
vortecman vortecman is offline
i have had my passenger window worked on twice for a totall of $600. AND IT BROKE AGAIN!! mabye i need to swap mechanics.....
Old 09-22-2007, 02:25 PM
envoyxuv envoyxuv is offline
If you try to operate your window and it does nothing but you can hear the motor running and it sounds like things are twisting and grinding and popping inside of the door, your window regulator cable is destroyed and the regulator should be replaced. If you try to operate your window and absolutely nothing happens (no motor running), and provided you have power and ground to the motor, then the motor is most likely frozen.
Here's the disclaimer: The motor and regulator can be replaced seperately of eachother. However;
1) if you replace one half of it (regulator and not the motor, or motor and not the regulator), it is very possible the other component could fail shortly afterwards and you would have to go through all the motions again.
2) Even though the motor and regulator can be replaced seperately, no one said it was easy. This can involve saying lots of bad things and throwing wrenches across the room. If you are in the process of replacing a component and the spool of regulator cable comes untangled (even on a brand new regulator), this can be very difficult to re-wind.
My recommendation to save a lot of time, frustration, grief, and even money in the long run would be to replace the entire motor and regulator assembly. It is completely assembled as one piece when you get it and is pretty straight forward to install into the door.
